Howdy Pilgrim
- 255XD
I’m having issues with my Shorelandr trailer that came new with my 2022 255XD.
I already went through 4 brand new tires after one of them became almost completely bald on the outside tread. I hate to say it but I’ve trailered the boat less than 15 times. Maybe 1k-2k miles total
I called my Yamaha shop I purchased the boat from and went through the process of trying to warranty the tires. Took the trailer to an alignment shop, everything checked out perfect and within spec. They gave me all the measurements and good to go.
Noticed after last time to the lake that the boat just continues to feel like I’m dragging it at times. I have attached photos and it appears that the brakes are engaging and potentially staying engaged on the passenger side of trailer (starboard of boat). You can clearly see the wear between the two sides are not equal at all. Img 6671 is port side img 6672 is starboard side and much much more scored and deeper. This is the side where I had issues with the tire as well
Questions/Advice…
1. What could be causing this to happen
2. What are the replacement parts for rotors and pads? Trailer model YAV51TJXWMS0-16
3. Is it normal for them to brake down this quickly or how often do you change your brakes?
Any help is SUPER appreciated as we have a trip coming up that I have to drive 4 hours each way and just want to try and make it safe
Questions/Advice…
