Aqua Jetaway
- X
I thought I would let forum members know that I’ve made a pretty detailed (i.e. a little long
) YouTube video regarding Depth/Temperature Transducer Replacement in a twin engine Yamaha. This isn’t a particularly difficult task and requires minimal tools and limited mechanical/electrical skill to complete. I used the less expensive Airmar transducer with the NMEA 2K connector (exactly the same as OE except for connector) and the JB Solutions NMEA 2K to Yamaha T-harness. It all worked like a charm and saved at least a hundred dollars in parts.
This video should be helpful for anyone needing to replace their depth/temperature transducer or the their depth/temp/speed transducer as the process is virtually the same. However, the transducer part numbers will be different.
Regards,
Ron
Regards,
Ron
