Stereo FS: Yamaha Jet Boat Plug-and-Play Audio Harnesses – $150 (Intro Pricing)
Brandonloos_21
Myself (InTune Customs) and Jon Cain (ATA KC) teamed up to design a brand-new OEM Integration Harness that makes audio installs plug-and-play on Yamaha Jet Boats.
🆕 Yamaha Cabin Amplifier Harness – $150
  • New dual-function design – use the same harness to add an amp OR replace your factory amp
  • Includes both input & output harnesses
  • Built for HTX 4/6 DSP OE Amplifiers
  • Two configurations:
    Add-On Mode – Keep your stock amp and expand your system
    Replacement Mode – Fully replace your stock amp; plugs directly into the factory speaker wire harness for a clean install
🎵 Additional Yamaha Applications
  • New AR Boats (Silver Amps) – Harnesses/packages available for amp replacement
  • Yamaha with Hertz Amps – Supported as well, though these setups aren’t fully standardized (please inquire)
✅ These harnesses are designed to save time, avoid cutting into factory wiring, and give you a clean, OEM-style upgrade path. Whether you’re adding power now or planning a full system overhaul later, this harness supports both.
📩 DM me here or reach out directly to @InTune Customs or 724-884-6120 for ordering and details.
e2d5b90f-ed2b-4fcb-84fa-a1743b7899de.jpg9ce4746c-6c93-4039-bc8d-879ad7f7e286.jpg88e6e34d-03cc-4345-a885-c43f5bca3ab7.jpg
