oil leak from oil pump 242
Kdbskyler
242 Limited E-Series
I have a 2010 242 limited and want to see if anyone else has had a leak from the 1800 motor on 242 limited. I believe it may be coming from the oil pump. I check all around the oil cooler and there is no leak. If it is the oil pump, how hard is it to remove and to replace the Orings. I have not found any you tube video on this subject.
