ScratchCoin
- 252SD
Today I got a reverse module fault, boat went into limp mode. The buckets were loose and wouldn’t drop into place when putting the throttle in neutral. They also were low enough to disrupt the water flow and prevent forward motion, but wouldn’t go far enough down to be in full neutral position. I had to use a bungi cord to hold them up so I could get back to the launch. After getting the boat out of the water, nothing outside the boat seems to be damaged. I can’t find any info on this system, how it works, or where it is. Has anyone dealt with this? Really want to avoid going to the dealer for this.
The boat is a 2019 Scarab 255ID with the twin 250’s.
