Spacer and Washer found - Where from?
Chadharter
I was inspecting the inside back of my 2017 FSH 190 Sport like I typically do each year. I removed the back right bucket holder as that gives me a good look at all internal hoses, etc. I noticed laying down on the bottom what looks to be a spacer and large washer, not attached to anything. Does anyone know where they might have come from? Pictures below with the purple circle showing where they were laying. Again, this is right below the very back middle of the boat. IMG_2640.jpegIMG_2639.jpegIMG_2638.jpeg
From the diameter comparison of both, they don't seem to be from the same origin. Have you inspected this area before?
I have before but they were kind of hidden. I just happened to catch a glance of the washer. The spacer was really hidden. I just felt it when I reached in to get the washer. And the spacer looks brand new.
Check the hinges for the engine hatch, although I expect you'd notice if one were missing. Could be an extra that the assembler of the boat dropped in there during the build.
Most likely explanation is that it's leftover crap from the manufacturing process. I found a lot of nuts and bolts, (although not that small) for years in my boat.
Same, and not to mention most of the bolts/nuts were not torqued properly so they needed to be retightened.
