  • 🚢 JB Solutions: March Group Buy Extravaganza!
    JB Solutions is running a Group Buy for the entire month of March on all products $49.99 and over. Everyone is guaranteed a minimum of 5% off, with discounts climbing all the way up to 25% off if 25 people sign up. The more people that join, the bigger the savings for everyone.
    This Banner can be dismissed by clicking the "X" in the upper right corner
Strange issue developed last weekend, CDI, Engine cutoff failed to shutdown !
John M - Ingleside
LS
I was out all day with wife and son on my LS2000, after a few hours the port engine tachometer starts indicating a pinned needle at maximum rpm even though the engine is running at 3000-5000 RPM’s, and the throttles are at normal 20-40% positions. When I come out of no-wake zones, and rev up the motors, the port engine would shut-down with what I think is the result of the CDI shutting down to protect it. The other really odd situation, I started the reverse engine maneuver to go backwards then pull the engine cut-off while slamming from reverse to forward to blow grass out of the impellers, only this time the port engine now stays running ! What do you think causes this ?
I have spent a great amount of time cleaning connectors and trying to get this boat to a place where I could go out and not have issues, but then this started. I previously experienced bad grounds in the electrical box, replaced the bendix spring and magneto, but here we go again.
Any ideas ? I did buy a spare CDI months ago, before I discovered a bad magneto, so I have the ability to replace it, but I would love to hear if anyone else have seen this.
Oh, that is a good one. I have no idea. Yet.
But I am thinking that the failure to cutoff the engine is a) a big safety issue and 2) a big clue. I would start by pulling the engine cutoff switch, trying to manually shut down the engines (I don't recall whether it is a NO or NC switch--but basically try to manually do with the wires what the switch should be doing when you disconnect the deadman cord). Assuming that turns up nothing, then I would start tracing that set of wires back. Ultimately you should wind up at the CDI, I believe (where again, you can use a jumper to try to mimic a switch disconnect). Either along the way you will find a short which is wrecking havoc with your system... or you will be able to strongly suspect the CDI.
I think.
Maybe the loss of a ground somewhere?
Dennis and Tim, I think you both are correct, loss of a solid ground, poor connection. I just got a call today, the lift company wants to come out to pull the boat lift, so I guess I will have to fix it in the driveway ! Thank you for your input.
I’m really not at all sure how the electrical works on the LS. On my sx210, the lanyard switch (plunger) activates two separate circuits. One for each engine. Off the top of my head, this switch has two plugs, one for each engine. To eliminate the lanyard switch as a source of this problem on my boat, I would unplug both plugs and swap them on the switch. If the problem moves to the other engine, it’s the lanyard switch that’s the problem in one of the two circuits. If there’s no change, it’s not the lanyard switch.
Hope this helps you diagnose.
