Beachbummer
- Houston TX
- SX
Impacted plug is hard to explain as anything other than bad news. Can you share a picture? I would suggest removing plugs and rotating engine by hand to confirm it's locked up.Were there any odd noises ahead of time? It may be worth to remove pump to rule that out, but a smashed plug can't be explained at the pump.My boat recently started clicking vs starting and the starter solenoid had gone bad...again options if your plug was not smashed. Do you have a VoltMeter? you could measure voltage as you crank, and should see a good voltage drop as the starter does its best to crank your engine. Spinning it by hand with no spark plugs on would be a good health check of the engine too.
