Ozark
- 195S
From the link you sent it saysIt's the same type of system that a car PCV uses:
How Does a Positive Crankcase Ventilation (PCV) System Work?
Just seeing the phrase "positive crankcase ventilation" probably makes your head hurt, because it sounds, well, complicated. But it really isn't all that complex.auto.howstuffworks.com
“The idea of an oil and air separator is to extract the oil from the air before it's sent back to the intake manifold and put it someplace where it won't cause a problem, either back in the crankcase or in a small receptacle called a catch can.”
From what I am interpreting, the only difference in the factory installed oil separator and an aftermarket catch can is the destination of the “separated” oil. Sounds like the factory oil separator returns the oil to the oil pan, whereas a catch can would isolate/store it for disposal.
It seems the only benefit of an aftermarket catch can vs. factory oil separator would be to stop the separated oil from returning to the oil pan by storing it separately. However, it seems that everyone installing catch cans are installing them downstream of the factory oil separator, which would render the catch can useless in stopping the “separated” oil from returning to the oil pan if that was the goal, since the oil separator has already performed it’s task.
What am I missing here? How is a catch can beneficial in this application where an oil separator is already installed?
I also want to mention that I am in no way attempting to debate or prove anyone wrong here. Just looking to wrap my head around this.
