Talk me into, or out of, it
Greg L
SeaDoo
GTS
I have been close to pulling the trigger on a 2015 195 HO Impulse, but have some reservations. I've boated for 35 yrs plus, from 12 ft up to 24 ft, with the usual 2ft-itis stops. Never had a jet and they intrigue me, but I've done enough internet and web searching to be nervous about a few things...fuel consumption, slow speed handling and docking, and lack of trim capability, for example. And we boat on the Ohio River, which can be glassy smooth or very choppy. Any thoughts on these, or other points to consider? Will appreciate all help...thanks!
ScarabMike
Green Cove Springs, FL
@Greg L Welcome to the Jetboaters.net community, and the Scarab section! I hope you will find our little pice of the internet informative, and entertaining.
Let me try to answer your questions as best I can.
Fuel consumption: Jetboats will use some fuel, but not as bad as some of the outboards or even stern drives. You can get 6gph avarage on the 195 with no issues. And thats on the supercharged engine.
Slow speed handling/Docking: The Scarab handles incredible in slow speeds almost precision-like. Its like you have a joystick on the big boats. Docking is even better. The only challenge is that the controls are reversed on Rotax powered boats when in reverse. You drive the bow as you would going forward.
You should take a look at these SeaDoo videos to set you at ease.
https://jetboaters.net/threads/sea-doo-scarab-glastron-chaparral-how-to-clinx-series.5116/
Greg L
SeaDoo
GTS
Very helpful. Thanks so much for the quick reply! Any thoughts n handling rough water/tow boat wakes?
Boat Crazy
Lebanon Missouri
@ScarabMike would not steer you wrong. One thing he forgot to mention is that along with the jetboat, you get this forum. The best source of information about jet boats anywhere.
ScarabMike
@Greg L Scarab boats have a 20 degree dead rise, twin reverse chimes along the sides to keep everyone dry. The boats have no wood in their construction. They are SOLID. My 195 is great in the chop. I had a Sea ray 190 sport, and it would get pushed around badly. You'll love the ride.
Greg L
SeaDoo
GTS
This forum is a great help and you, sir, obviously know your stuff. I'm coming off a Four Winns 200 Horizon SS with 350 Mag and thru hull exhaust. Looking to reclaim the fun, but not the price tag. Looks like the 195 HO Impulse will work...until the next one comes along ;$). Thank you!
ScarabMike
@Greg L No problem!
The Four Winns Horizon is a nice boat! I couldnt find a dealer when I was shopping around before I bought my Sea Ray. I wanted to do a Corza exhaust on it before I sliced my leg on the prop. Then it was time to go. I think youll love the Scarab. Make sure you dont get suckered into a Smart Mat, they are garbage. Save the $1300.
Also, before taking delivery, make sure you check the trouble spots that are known.
1. Rust on the trailer bunks
2. Make sure your stereo works as it should. If it pops, or if your boat has the silver Sony, have them change it to the current marine one (its black)
3. Tug on the stainless "195" numbers on the windshield. If they are loose, or have a gap tell them to take them off and glue them properly.
4. Make sure all your LED courtesy lights work, and if you have the Kicker system, make sure your tower speakers work correctly and fade with the knob in the glove.
5. Make sure they test the trailer's surge brakes. There was a recall that affected only the 2014 models.
Scarab includes their own checklist with each sale. The dealer has to fill it out and send it in after delivery. Look for it, and take your time.
Icatfish247
Lake Loramie, OH
FWIW, parents have a Yamaha SX190(different boat but still a 19' jet) and they almost exclusively boat the Ohio River without rough water issues. Take caution around the larger cruisers and sometimes barges and the Scarab should be fine.
If your schedule allows it, the Ohio is a great place to boat on weekdays.
brockhals
Watersound, FL
Best option is to go out on the river and see for yourself. You can always add trim tabs to help with the chop. With minimal draft and no rudder/outdrive the wind will play a larger role in docking, trailering, etc but with practice you can predict and overcome.
Greg L
SeaDoo
GTS
Thanks, folks, for the Ohio River input. Very helpful! Some of the same conditions we've handled with a pontoon boat and pwc's, so they're not foreign. A couple last questions for now, I think. Anyone pull water skiers with a 195 HO? How do skiers like the wake, and is the power sufficient to get a skier up and out of the water quickly with the driver and two more adults on board? Of our boating group of four, all ski but me, the designated driver. Thanks.
Glassman
Redondo Beach, California, U.S.A.
Greg,
Buy the boat. With 35 years under your wing, you'll be fine.
Go have some fun. These boats do cause wrinkles though. Can't help that what with the permanent ear to ear grin that comes standard.
Best regards,
Glassman :cool:
Speedling
Cedar Lake, IN
SS
Or see if you can get a test drive? Or someone from these forums? Or stop by a gathering, although that woukd put you without a boat for a good bit yet then.
@Greg L - You mentioned the lack of trim capability in your original post...many jet boats don't offer trim capability because they have almost no bow rise due to the thrust being from the transom rather than under the boat. It would be nice if we could trim the boat to force the bow down, but we don't via the pumps, but you can add trim tabs if this is something you feel you must have.
Greg L
SeaDoo
GTS
Thanks, good tip. The area on the river we boat---around Rising Sun, Indiana---isn't crowded weekends either.
Greg L
SeaDoo
GTS
Greg,
Best regards,
Glassman :cool:
Thanks, Glassman, at my age what's one more wrinkle...
RFScarab
Folsom CA
HO Impulse
I can't lie coming from prop boats a jet is odd at best to begin with. I am on my 3rd trip with my 195hoi and it takes getting used to at the dock. Not that it's not maneuverable, it's just different for me personally, with a boat that tuns in neutral and reverse is opposite of what to me is the norm. Beyond that this boat rocks!!! It is a blast and does things a prop boat cant. I was nervous myself but am very happy with the Scarab. Enjoy whatever it is you decide on. Oh and the ride is great even in large chop. I was concerned with that as well but it rides amazingly well at all speeds. You can tell the hull design was very well thought out. Dry passengers with no spray even in large waves also.
MikeyL
Passed Away
In Memoriam-RIP
Lake Oconee, GA (Greensboro)
I have been close to pulling the trigger ....... Never had a jet and they intrigue me, but I've done enough internet and web searching to be nervous about a few things...fuel consumption, slow speed handling and docking, and lack of trim capability ..........
One of the most IMPORTANT benefits of jet boat ownership to Barbie & me is we no longer ever again have to mess with, and hate, is "trimming" the motor constantly !
Just give it gas and go ! Good Luck in your decision. Mikey Lulejian - Lake Oconee, GA
Joseph Baxter
HO Impulse
Let me just say this is the first boat I have owned so I cannot really make too much comparison. I will say that I have found my Scarab easy to drive whether idle (You'll understand when you drive one a jet), no wake or fire walled. At first I was a little hesitant about trailering but the Scarab was very responsive to control inputs.....simply put it did exactly what I wanted to. Not to mention the Scarab (and Yamaha I believe) have a docking mode that prevents you from incidental thrusting of the lever and subsequent shooting over the mark. And as @Boat Crazy said...you get this forum and all the fellow jet boaters willing to help. In the end...you will make your own decision so good luck in whatever you decide.
ptdavidson
I do not see an answer for you question about pulling a skier so here it is. This boat will pull a 200 lb slalom up in a snap, plus you have the option of adding the "ski mode" which will give you pre-set launch settings and top speed settings so your friends or wife won't pull your arms out.
Greg L
SeaDoo
GTS
Thanks. That's a cool feature the crew will like...and make me look better.
