Yamaha/Wet Sounds DSP Harnesses
Brandonloos_21
Hi all,
I am making harnesses to either use different amps in place of your wet sounds dsp amps (if upgrading), or to repurpose the stock dsp amps in another application that needs RCA and speaker wire out.
Feel free to reach out if you need one!906586D4-9402-4C40-8EE4-26F29BA272DB.jpeg870A9E00-FD3C-42AB-8BE5-95BEA4C04C61.jpeg
cesarcandamo
How does this work?
Brandonloos_21
How does this work?
They just plug into the factory DSP harnesses that yamaha currently has plugged into their amps to let you use regular amps.
OR, they plug into the DSP amp to be used with a regular (non dsp) system.
cesarcandamo
I see 3 cables... Do any of those connect to the RA70 radio that is in the rear?
Brandonloos_21
No, that should be plugged straight into your blackbox. These are just adapters to go from the amp plugs coming from the blackbox to rca's/speaker wire
paharam
212X
Just wanted to share that I bought the main cable harness for my new install. I removed the DSP amp and replaced with 2 HTX6s. Added a second sub and replaced recons with revo 6s. Huge difference from stock. This was done on a 2020 212x. It is working great and saved me a lot of time not having to take out the head unit and deal with the fusion harness. Brandon was quite helpful during the entire process as well.
tabbibus
Lake Lanier, GA
Can't wrap my head around this. Can you tell me about more?
mike mews
SeaDoo
Challenger
I have a 2022 AR250 and trying to add an additional amp and 2 tower speakers. Plan on keeping the existing stock amp. Having issues connecting the new amp to the system. Would these work for my situation?
jacoviii
Independence Mo
255XD
Yes and no. You can use this to connect as a pass through but you may still need a Audio control LC1. The head unit ( Conext screen) is sensitive to changes. Some have reports that it will shut down out put channels if the ohms are not correct. Needs to be 20kohms or more. So by adding a amp and parallel the signal to 2nd amp may be ok. You will need one that is male and female also zone out as need. 20220506_170530.jpg
mike mews
SeaDoo
Challenger
Thanks Jacoviii. I have decided to take to a professional and let them install the amp.
2019se
Hello,
Are you still making these harnesses? Planning on replacing the WS amp in my 2019 e series with a JL amp.
jacoviii
Independence Mo
255XD
Hello,
Are you doing a full replacement? No wet sounds 6ch?
2019se
That's the end game but this year all that in the cards financially is the amp and maybe the sub. 6.5s next year.
2019se
Sorry, miss read your message. Yes, no WS amp. Completely removing it.
Xixp
Im interested …ive just sent you a PM. (I want to replace the dsp htx with another amplifier, poasible Fusion or regular WT htx 6)
Brandonloos_21
Hello,
Yeah I am! Reach out to me, 7248846120. I see texts as soon as they come in rather than the pms here!
Brandonloos_21
Hey all! Got a bunch of these harnesses for installation of aftermarket amplifiers. Give me a shout if you’re looking to upgrade to aftermarket amps in the offseason !
adrianp89
Tampa Bay, FL
252SE
What is cost?
smogden
Fernandina Beach, FL
222SE
I have a 2023 222SE. I have been trying to wrap my head around how to do my audio upgrade that I want to do. I was figuring just cutting in to the high level wires. But do these just allow you use RCA’s? How does it break down the signals?
Brandonloos_21
Yes, depending on boat, it gives the 3 zone signals out in RCA, plus a remote signal.
