- Raleigh, NC 27614
- 242X E-Series
FYI---this list HAS BEEN translated to the site's new FAQ feature we added.
So please check out the FAQ before posting in case there is already a thread on your topic.
Here is a list of great information for members to leverage to answer questions about jet boats. Please reply to this message if you would like me to add something to the list! This is built by members for members!
If you are on the water and need help ASAP feel free to use the [USERGROUP=9]@HELP[/USERGROUP] in your post-and those subscribed here to help will get an alert. It must be in the body of the post NOT in the title.
Maintenance: (ALL of these are copied to the new FAQ)
- Spark Plug change step by step (also attached below) and video (link to Youtube video)
- How to remove stuck Oil filter
- Plug change step by step document and step by step and video
- Plug change and plug sheared off--How to remove
- Engine Flash codes (if your engine lights are flashing after you start your boat)
- Bearing greasing-Cone Bearing breakdown, Cone bearing maintenance, Intermediate bearing greasing, intermediate bearing replacement
- Winterization Checklist and video
- YDS Operation and overview
- How to Adjust reverse gates if your throttles chatter or your boat creeps forward to hard. Another thread with info on adjusting reverse gates.
- Thottles slipping back? How to adjust
- How to replace reverse gate cable, and a How to for 2007-2009 boats (see #31 for steering cables)
- How to dis-assemble Jet pump video, and photos
- Trailer Maintenance, how to replace winch strap, Shorelander grease point, Trailer Brakes replacement parts list
- Clean out Plug fixes and maintenance, 1) Repair kit from Yamaha 2) Thread with photos 3) One members fight with his plugs
- Engine not starting diagnostic
- How to clean intake screens or strainers
- How to fog your engines (by engine type) - SX230
- Engine cooling issues--video of how cooling works
- No Wake Mode not working?-adjust throttle stop
- Replacing Anodes - both engine and external
- How to replace Hydroturf decking material, JetboatPilot How to Video
- How to replace gas filler hose clamps
- Scuppers--How to install new SS Scupper, and a Thread with more photos and part #'s and a thread on borrowing pre-made scupper wrenches to fit in the small gap in the bilge.
- Yamaha Tech Bulletin on Plug Maintenance
- Polishing and Waxing your Boat
- How to replace your solenoid and remove ECU box
- How to remove an engine
- How to replace a starter
- 07-09 Fuel tank cover tool (to remove the flooring)
- Oil Cooler sheared off bolts (2010/2011 1.8L engines -need models affected)
- How to replace Steering cables
- What is in your oil filter? Anatomy of a Yamaha Filter
- Gas Gauge not reading right on older model (pre 2009) boat--replace the fuel sender
- Throttles out of Sync....directions on how to fix
- Aligning the powertrain on 2005 SX230
- My favorite Yamaha parts look-up site
- Yamaha 4 Cycle (230 series boats) MR-1 Filter (page 7-KN-303) and Spark Plugs (CR9EB), an alternative filter alternative
- Yamaha 4 Cycle (210 Series boats) Spark plug and filter thread
- Yamaha 4 Cycle (240 series boats) Filter (K&N HP-1002) and Spark Plugs (#6668 LFR6A)
- Are the 210's plugs and filters the same as 230s?
- Replacement door trim
- Engine Flush connector
- JETBOATERS.net SWAG-Flags, Stickers, Coozies, shirts....
- Replacement Tires
- Pins for 212x Tower
- Ladder Strap replacement
- Older Model table post base
- Bimini "Boot" cover
- MANHOLE COVER REPAIR SET - FOR-67609-09-00 (clean out plug repair kit)
- Replacement fuel sender for older model - fixes gauge mis-reading
- Wire Connecting specialty connectors-really cool for adding/piggy backing wires.
- How to Spot if Someone is Drowning, Drowning is SILENT <<<<<<READ or WATCH ONE of these - PLEASE>>>>>>
- Checklist for launching and retrieving
- Checklist when picking up a new boat (or used)
- How to contact Yamaha and YES departments
- Free Boater Education Classes
- How to fix gelcoat scratches/gouges
- Differences between the 4 Cycle Models
- How to replace sticky/gooey storage cabinet door trim
- How to clear a pump clog easily AKA The reverse cleanout trick
- How engine cooling system works (video)
- Bow stop loose? Weld or bolt it.
- How to install Keelguard or KeelShield
- How to put on/install mooring cover
- Depth Gauge Manual
- How to Set an Anchor
- Boattest.com docking instructional video
- Sources for Boating Covers:Covers Direct
- Trailer 5 pin to vehicle 4 pin wiring solutions
- How Not to have your table leg sink to the bottom!
- Comparing the Wesbar light fixtures with the Blazer LED modules
- F150 mirror upgrade
- List of Nautical Terms
- Trailer lockout key replacement options
- List of things (like tools) to keep on board
- Want a spare set of keys made cheap--here's how
- Battery/Charging -All about batteries and charging!
- NADA Pricing for Yamaha Boats (for some reason listed under PWC)
- Trailer Tire Changing Tips
- Great analysis of Engine Noise and Gas Mileage comparison to other boats
- How to Install Boat Buckle retractable transom tie downs
- How to Install Cobra Fins
- How to Install Thrust Vectors
- How to Install Tru Locks
- How to install EZ Locks
- How to install Trim Tabs
- How to install (and info on) an Airdock (floating lift)
- How to install larger speakers
- How to replace stock ladder with a better one (and part#s)
- How to install a fume detector MY BEST SAFETY MOD!
- How to install sound installation, Another thread on accoustiblock with video, and another thread on replacing engine soundproofing, and another sound install thread
- How to Install Shut off valves
- How to add cup holders and cup holder trash bag mod
- How to Install LED lighting
- How to improve storage in your storage closet
- How to install/add extra 12V or USB power ports
- How to add more ballast
- How to add a Barbecue grill
- Who to order Custom Vinyl Name Decals from
- How to replace 5 pin trailer plug with 7 round connection
- How to install a full Camper or rain cover to your bimini
- How to install a Switch Panel (to add more electronics)
- How to install LED lights on your trailer (and rewire it)
- How to relocate Cruise Assist to the Throttle lever (AKA Binnacle)
- How to install a storage hatch door on our 190/192 series boat
- How to install a refrigerator on your boat
- The "Wake Wedge" revealed
- How to install Wakemakers Ballast
- How to install a computer controlled ballast system
- How to install Seadek, and how to remove the old material
- How to install a fresh water shower
- How to add a spare tire mount and new jack stand
- How to Install a GPS Chartplotter
- Underwater LEDs
- Stereo upgrade thread
- Replacing JVC Headunit with Clarion and new remotes
- Installing 7.7 inch speakers to replace 6.5s
- Adding speakers without adding an amp
- How to install Perfect Pass - photos of the install
- How to calculate the right wire gauge for your wiring project
- How to pull wires through your tower
- How to build your own fiberglass speaker enclosures
- Stereo wiring harness schematic
- Clean your hull for 50 cents
- Buffing/Waxing your hull
- Boat Bling Products
- Magic Erasers and Part 2 - great for the floor and all sorts!
- Our Code of Conduct
- Our Operation Expenses and Contributions
- Business Card template
- JETBOATERS.net SWAG-Stickers, Coozies, shirts....
- Our Committee and Moderators
- How to use our forum - [HASH=540]#features[/HASH]
- A list of all the available Trophies you can be awarded
- Vendor Forum
- Member Map put your City/State (and opt. Zipcode) in your profile personal details section
- Link to our Member tips section
- Where did your screen name come from?
- What do you do for a living?
- Show us your boat- Post up pics of your boat/family etc
- What do you tow your boat with?
- Show us your boat names!
- Interested in meeting up with other Jetboaters...Check out the gathering forum!
- How to easily add hyperlinks to your posts
- How to post or link to pictures in your posts
