Looking for help
michael D Kasparek
Chaparral
VRX
Not my first boat but,first jet boat I have a 2018 chaparral 203. Anyone know how to make the steering better at low speed.
Compatico
Wandering more than a single prop boat is common with a jet as it doesn't have anything except forward thrust. Jetski owners don't have the issue as much but only because they spend more time at higher speeds - LOL. I took a 203 out on the weekend and found you can play tease with the the throttle to help minimize the wandering (give a little, then back, then give a little, then back, etc) since under power it tracks fine. Also since the steering is so quick, sometimes people overcompensate by going full lock to lock to try to get it under control, but small movements work better - just a bit to the port/starboard to smooth it out.
There's a user here who makes a "rudder" that apparently helps for low speed maneuvering, you might want to try that if the wandering is too annoying. Search for @JetBoatPilot who makes an addon device called "thrust vectors".
MidnightRider
Zumbro Falls, MN
Malibu
Wake
Just do a search for "fins" and you will enough reading material for the rest of the year to try and figure out what solution you want to go with.
michael D Kasparek
Chaparral
VRX
Thank you I will try to find him
michael D Kasparek
Chaparral
VRX
Now that boating season is almost over I will have time to read. thanks
JetTech72
SeaDoo
Challenger
With practice I found out that less steering input & bumping the reverse gate down briefly, would help keep the boat straight at low speed
