jcb1977
- Elkhart Lake, WI
- SX
might be a dumb question but is there any concern with wiring two fuse blocks in series on the same fuse? see sketch below. I think 80 amp fuse will be more than enough for everything i'm going to power on those two fuse blocks so not worried about that. Just not sure if it's acceptable practice to wire them in series. each fuse block is rated for 100 amps in total and max 30 amp per circuit.
