‘24-‘25 255XD What to look out for
Igetwet
SeaDoo
Speedster
The family and I have been checking out a few 255XDs lately. Sold a couple of our other boats to make way for a new one. Question for current owners and others that have bought recently, what are some common issues to keep an eye out for? Major or minor issues.
I’ve noticed so far:
Passenger side storage locker door does not close nicely and the top hits and rubs while there’s still a gap at the bottom.
Captains chairs are a bit clunky. They don’t feel tight and are cumbersome to swivel.
Misaligned/not straight marine mat install.
Rigging not the greatest, lots of wires just ran here and there. Somewhat to be expected for a high volume production boat and is fixable.
What else?
I haven't noticed any of those items on mine. The only issue I have had is that neutral isn't exactly neutral. There is a slight bias towards reverse. I've been enjoying the boat too much to take it in and get it adjusted. It's a bit of a pain since when docking, I tend to bump puffs of power by going between forward and neutral, and it requires that you reverse steering when going back and forth to keep the same heading. The service manual is a bit cryptic on the topic (because of the computer control, it isn't a simple matter of just adjusting bucket position) but I'll get it sorted at some point. I didn't notice it on my sea trial, but you might check it on your sea trial in case it's an issue. There are a couple of others here on the forum that have noticed the same thing.
Other than that, fit, finish, deck mats, latches and wiring are all great on my example. Captain chairs are what they are by design. They are cumbersome to swivel, but mine are tight at least.
The captains chairs most likely were never lubed properly. Once the mechanism is cleaned and lubed they will be much better i am sure. Mine were crappy when new but after addressing them properly they have been great since
Great. Good to hear. Figured it was something that could be fixed with some TLC
I used a couple of small pieces of weather striping around the head compartment door in response to the rubbing at the top.
Watch out for the triangular piece of trim around the storage compartment behind the captain's chair. I had someone stick a too-big bag in there, and when they pulled it out it pulled the plastic trim which stripped one of the screws. Fixed once, then happened again the next summer. Bad design there.
I had 2024 255XD (I traded it in for a 275SD), and it is a great boat. My biggest complaint was that so much of the storage was lost to the Fat Sacks used for wake surf ballast. Granted, when they are not in use, you can use the space in the ski locker and under the rear seats for storage, but to fill the bags, you have to take everything out. Other wakeboat manufacturers have solved this by placing the ballast under the floor. I, too, did not like the way the seats worked and was going to replace the pedestal with a Springfield air-powered one (it's hole-compatible), which I also plan to do on the 275 as I don't care for the seat mechanism. https://www.amazon.com/dp/B07D1DJ8V...FBEFF39X&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
Brought a new 2024 255XD home on Thursday. Loving it so far other than cosmetic blemishes. I realized the captains chairs will not be tight until you turn the clamp part tight. Never laid down and looked under there at a dealer or show. Still a bit cumbersome to slide and swivel, but better than I originally thought. Looking closer at the head door I see there’s adjustment with the bumpers or stops there too, so may be able to alleviate that issues as well. IMG_0893.jpeg
Congratulations. Beautiful boat. Many of the boats of multiple brands untested had similar issues. The seat mechanism is not great. I’m thinking of trying this https://a.co/d/1Bkwwke
Brought a new 2024 255XD home on Thursday. Loving it so far other than cosmetic blemishes. I realized the captains chairs will not be tight until you turn the clamp part tight. Never laid down and looked under there at a dealer or show. Still a bit cumbersome to slide and swivel, but better than I originally thought. Looking closer at the head door I see there’s adjustment with the bumpers or stops there too, so may be able to alleviate that issues as well. View attachment 234199
Congrats, spray lube is your friend with the chairs, after a yearly squirt my 2 captains chairs work perfectly
Took the boat out on Sunday. Everything went good except we were taking on a fair amount of water while cruising to where the bilge notification came on in the screen. Looked at pump clean outs right away and they were full of water. So thinking water is being forced through those then draining down into the bilge.
I know some water on top of the ports is not uncommon, but this can’t be right. Salesman says water in the clean outs is normal but he agreed not this much. There’s no grease or bees wax on the clean out now. Will that cure this much water coming in?
I am still chasing this down on my 2024 255xd. Always have excess amounts of water on in the clean-out ports. Put in the riser kit, sealed the bildge deck, but still have water in the bilge and pump out about 1/2 gallon or more every hour. Even with no one getting in the water.
I did locate 1 leak and it turned out to be the underwater LED light was cracked. Dealer was going to replace it but it was on backorder for 6 weeks. OEM part is crazy expensive so I purchased a better IMO unit off amazon and installed it myself.
Headed out this weekend to keep searching for other water intrusion. Will keep you posted.
What is the riser kit?
I’m fairly certain we were only taking on water while underway, but had friends out with us so did not investigate much when we were parked. My clean out plugs are not greased at all so I’m thinking that’s most of the issues. They still fit and lock into place fine, but after reading another thread about the success of the beeswax in the clean out seals, it seems the grease or wax also provide some sort of physical barrier.
Anyone else have issues with the passenger side “cabin” door opening in its own during towing?
Anyone have a picture how how their sound bar is mounted?
And what is the consensus with towing with the Bimini cover on? Dealers says take it off for highway speeds, but that’s a lot of f’n around when most lakes we go to we take the interstate.
Buddy of mine with a 242x tows with his on. Other members do as well. I think 70mph and under you're fine, but I'd still be paranoid about it.
Water comes from everywhere on these boats.
#1 place to check first is your anchor locker drain. When loaded with people in the front, and motoring at off-plane speeds, that drain will take in water - Yamaha does a terrible job at sealing it on the inside, so water slips between the outside hull and the inside anchor locker, going directly into your bilge. I plugged mine years ago with silicone.
#2 place to check is your cleanout hatch. when you open your hatch (or maybe hatches in your case), you'll see a cover that's screwed down, and a cover that pops off easily, and you should see a drain.
- Check that the drain is draining (run a hose through it)
- Add silicone to the cover that's screwed down
- Buy a riser to elevate the easy-to-remove cover, that brings it above the water line
- Seal your cleanout plugs (search the forum for different methods)
#3 place to check is your self-bailing deck scupper, which is the transom drain for your interior. That drain will be connected to a hose that goes to your deck. Check to ensure the hose is connected and that the scupper itself isn't leaking
#4 place to check is your cooling lines coming from your pump. Each jet pump will have one water line coming in from it, and then it'll split and go to the oil cooler, the exhaust manifold, and to your visual cooling indicators (pissers). Make sure they're connected and tight.
Finally, these boats just get water in them. No matter what you do, drain the boat after you use it. You'll take on more water if you're surfing too, as pumps are running high pressure, the hatch drain isn't draining as quick at low speeds, and you're getting water over the swim deck when stopping.
One way to get an idea of where the water is coming from is feeling it's temp. Cold or lake temp water will indicate it's coming from outside the boat, hot water means it's coming from your motor somehow.
I consider 10-30 seconds of water coming out of the bilge is totally normal after a day of boating, even with all the sealing you can do.
I've had my cabin door open while towing sometimes. It has always been user error. The latch isn't bad, but it is a little finicky. Most often is my kids will snap it down the wrong direction and it will appear latched but isn't.
I have a buddy that has passed me on the interstate doing probably at 85 with his Bimini up on his poontoon, so I’m fairly confident these big towers and ratcheting covers should be able to handle 70-75mph.
I totally get water will get in somehow with all these ports through the hull, but the red bilge light coming on, which I believe just means float switch has kicked on, after just a couple minutes of cruising isn’t acceptable
I will throw my $0.02 in here...can it handle it. sure. Does it add unnecessary wear and tear, yes.
I would think that running the boat at 50-55MPH on a windy day would be relatively close to the same impact as trailering it at 65-70MPH.
