08 YAMAHA SX230HO
DawgDaze
Lake Elsinore, California
I have a friend that has a boat like mine and the steering wheel cable is sticking.
It takes much effort to turn the wheel. Any suggestions?
First you need to determine weather it's the cable, jet nozzle or helm causing the problem. The most common cause is cable. While on the trailer you should disconnect ONE of the steering cables from ONE of the jet nozzles. Doesn't matter if you start with the port or starboard side. Once removed try turning the wheel. If it turns freely now, you have identified a bad cable. If it's still tight, disconnect the other steering cable. If the wheel is now easy to turn, that is your troubled cable. In either event if either cable is binding you should replace both.
If neither cable resolved your issue you most likely have an issue with the helm or the cable linkage connected to the helm. It may just need grease to resolve the issue. You can also check the jet nozzles by turning them left and right by hand, while disconnected from the steering cables. It's possible you have a bad bushing but not too likely. Let us know how you make out. Also, have your friend sign up to JETBOATERS.NET so we can give him some first hand info and he can meet some fellow jetboaters.
