msavold
- Columbia, MD
- SX
The folks on here that know the boat much better than me might correct me here but...
This week end I launched our SX240 with a boat full of people (one a Lieutenant Commander in the Navy...), triumphantly announced "we're off", throttled up and... we didn't move. Gave it more gas - still nada, More noise but no movement. And the light bulb came on. Walked to the back, popped the hatch, re-seated both plugs that were just loosely in the ports, and we were off. Bilge pump was on and not a drop of water came out.
My point is that AFAIK, there are only five ways that a substantial amount of water can get into the bilge: 1) drain plug not in (ask me later how I know that one), 2) clean out plug tray not sealed around the perimeter (the white part with all the screws in it which on some later boats has shipped without adequate sealant), 3) the hose clamps loose around the black hose you can see when you look at the plugs, the one that connects the bottom of the boat where the pumps are to the tray at the top (note: clamps only visible when you remove the inspection hatch in the clean out plug tray, the one between the two plugs), 4) a CRAPLOAD of water on the boat from say, a sub move or a wave, and 5) a gash in the side of the boat!
As an aside, from what I've read here from the unfortunate few that have taken on water after a true plug blow out while under way, it's much more of a catastrophic event - as in "oh, look, there, in the sky, there goes our plug!". Which is why plug locks - or at least nerf footballs, if not both, come so highly recommended here.
So, don't beat yourself up over this - assuming that the drain plug was in (& not leaking somehow), you didn't take a huge wave or gash the bottom of the boat, there is really NO WAY that you could have foreseen either of the other two possibilities - new boat owner or otherwise. And just having the plugs out - without one of the other two issues (clamp/sealant) present, should just make noise but not let water in.
And then there is the matter of the bilge pump not running unless the switches are on both on and "combined" (basically an 'emergency' condition - when one battery doesn't have enough juice and both might get 'er going)...
Huh?
I just checked - your boat has something like 167 HOURS on it per your old post? And the bilge pump has NEVER worked properly? (How could it have if it was wired "weird". I think we've pretty much all had that "oh, crap the drain plug!" moment - at the very least there must have been some occasion for the bilge pump to come on...) Why do I see a BS flag waving?
(BTW, remember that when the hull is in water the bilge pump is ON. Since it should be on even before starting the engines, when you hit the switch you should be able to hear it run for a few seconds.)
Do you have service records on the boat? Can you get them to see what's been done in the past 167 hours? Just out of curiosity mind you. Bottom line - if they're going to fix what we all pretty much think was THEIR screw up, and assuming your drain plug was tight
