2004 LX210 Fuel Line Leak
BigMatt
LX
I detected that my 2004 LX210 2 stroke starboard engine developed a fuel leak right at the connection of the fuel hose to the carburetor at the rear of the engine. But the position of the hose clamp at the end of the hose is really impossible to reach with a screwdriver or small socket wrench. Also, I can't really see the condition of the end of the hose, to see if it may be cracked or rotted from old age. How much of the top of the engine must be dismantled to get at that fuel line clamp? I would like some advise if somebody else already changed their fuel lines - how hard was it to access that connection? Trying to learn if this is an easy fix or if there is a ton of work to get access to that clamp.
A well lit pic might be useful to the collective. From your explanation I'm thinking I might use a dremel to carefully cut the clamp and replace the entire flexible line.
I thought I had a leak at the fuel line as well but it was the carb leaking I used an inspection camera to see what was going on and it did help some. In my case I was able to access the lines once I removed the arresfor from what I remember.
Thank you for the reply. I think I was over-thinking trying to find / fix the leak. Instead I will just use this as an opportunity to change the fuel filters and lines. It can't be too hard to take the carburetor cover parts apart to get access. (Fingers crossed.)
You could also ditch the fuel filters and put in Sierra water/fuel filters as an upgrade. With the water that can condense in the tank, these are a plus
