afdouble
- Upstate, South Carolina
- 242 Limited S E-Series
After using the search function and reading most of the "scupper" related posts, I do not see a consensus on whether changing to a stainless steel scupper is warranted on the newer boats (I think 2015 and newer) where the scupper placement is higher , and possibly above the water line.
As such, I thought I would start this post to get the Board's consensus... Have you replaced your 2015+ scupper. If so, Why? What part did you use as a replacement? How did the process go?
OR...Did you decide against it? If so, why?
ALSO..Pros/cons... Deciding too, but waiting? Haven't made a decision yet?
What are the Board's opinions?
