- Rosebud, Mo
- 242X E-Series
I mean with reverse wiring. Do you think so J&*^ A&* just said one day " Watch this ".
Julian if you have a voltage drain I would HIGHLY recommend looking here.
https://www.amazon.com/ECO-ENERGY-Ganz-Eco-Energy-Semi-Flexible-Solar/dp/B00FWS4KKG
I mean the wiring issue.......Why would I need a 3rd solar panel?
It doesn't suprise me that this is only now getting uncovered....I've not trusted that the panels would charge my boat in the slip, so I've had a dual bank charger on my boat since I bought it. I've never noticed an appreciable charge from the panel....and as I said earlier...have wondered if they were actually draining the batteries! I'll look at my wiring this weekend if I can!
When installing a controller do you want it closer to the batteries or the panels?I have done a bunch of solar panel work. Using the panel direct to a battery can be done but is not ideal. It looks like Yamaha gets away with it by having large batteries and tiny panel, that way the panel voltage doesn't overpower the electrical system a and raise the system voltage in the boat over what the battery is putting out. Not what I would do. It is not a great way to charge a battery as the voltage needs to fluctuate at different states of the charging cycle. Solar panels add voltage when put in series and add current when put in parallel. From the pics it looks like they are wired in parallel. What is the OC current output. With panels you can simply put your meter in series and set it to amps (as long as the meter will go to 10A). For example, while WAY bigger, my RV panels put out 35V and 9A in full sun. Can the yamaha panels get the batteries to 14.4 V? Typically most OEM solar systems are underdesigned. Cam.
So you left the wires at the batteries (G1 and SP1) connected to their factory connection points and and swapped the wires around in the box on top of the tower (between the panels) so that positive and negative leaving the box were reversed?So I swapped the positive and negative lead and hooked everything back up. When the starter battery wasn't hooked up the red light was blinking indicating it was charging the house battery and when I hooked up the starter battery it went off indicating it was charging the starter battery. All is right in the world again and I can get some sleep now.
I don't know if it matters or not but I am going to mount mine to the same wall that my switches are on so it will be closer to the batteries than the panels.When installing a controller do you want it closer to the batteries or the panels?
Was this photo from before or after you swapped the wires? If it was before, then clearly they'd swapped red and black...but I suspect this was after...Yes, but you need to make sure that the sp1 and the G1 are wired in reverse before you do this.
Based upon what I can see in that photo post swap the reverse polarity issue may be at the panel assembly line and not Yamaha's fault.Was this photo from before or after you swapped the wires? If it was before, then clearly they'd swapped red and black...but I suspect this was after...
And what controller are you getting?
Now that mine are fixed I will fell the same way.I have a 2016 242 Limited S e-series boat, We've left it running with radio blasting for 4+ hours, the charge was at 12.3 to 12.5 all day, during the evening before we started up, we were down to 12.0 to 12.2, It seems to think mine are charging properly.
I will add I love the comfort of these solar panels, i use to worry about running the stereo without starting the engines but now I am much more confident
This doesn't make any sense to me. If you crank the stereo it should only deplete the house battery, not the starting battery....However, with a 600 watt stereo system that can pound for 6+ hours I did have to use the "emergency parallel" switch to start the engines and let them idle to get up to operating voltage.
