Welcome to Jetboaters.net!
I just got this boat and I'm reading it should be in the mid 40s at least for mph. I am only getting about 35-37mph at 7500 rpm. Both motors only have about 65 hours on them. Any thoughts on what the problem could be?
1. 555'
2. 2 humans and a small dog
3. Lake
4. Not sure
5. Very hot and humid
6. Even??
7. Nope, not sure how to do that but I'll look it up
8. Same answer as 7
9. Just bought the boat so I haven't done anything
1. 555'
3. Lake
4. Not sure
6. Even??
8. Same answer as 7
If you JUST bought the boat, even from a dealer, for sure spend the money to change your oil and spark plugs. You can get ahead of many issues with that simple maintenance
Make sure when cold and level the oil reads pretty close to the low mark on the dipstick. Either way, I have always averaged around 38-39 with a full tank and 4 people. Two people on a half tank will sometimes get me 40-41. Not that I run my boat at top end for very long but it is a good indicator of how she’s doing. They aren’t powerhouses so every little thing (as mentioned above) affects top end on the TR-1’s. Oil level, humidity, elevation, temperature, weight, etc…..
So I just ran it about 10 minutes on the water. Stopped and waited about 7 minutes. Checked the oil level and it was above the full line on the dipstick. Is that normal for just running it? If not do I just need to pump some oil out?
I did order a full oil/plug change kit and will switch it all out next week, just wondering what I can do to improve performance over the weekend.
Also my air filter has like a blue on it... Picture attached.... What would that be from?
The blue reminds me of fogging oil used for winterization. Not sure how it would get in the filter unless it was accidentally sprayed on it while fogging the intake.
As for performance, make sure the impellers are clear from debris just in case you sucked anything up. Spark plugs would be the more immediate result for performance.
yea pump it out, start with 1 cup then recheck after running for a min. In a pinch if you don't have a pump you could probably get away with a turkey baster.
Update: swapped out the oil and spark plugs. Still only getting about 28mph with 3 people and 2 30lb dogs on board. Really at a loss here for what's happening.
If you wet slip your boat it will cause your boat to slow down. If you live in the south, it will have a bigger impact than if you live in the north (Like WI or IL).
In Wisconsin my boat would lose 5ish mph when dirty. In NC my boat loses 15mph when dirty. In NC it grows a fuzz on the hull which is like driving a sweater through the water....TONS of drag. This is why I bought an airdock (see the link in my signature - if you cant see my signature-turn your phone on its side).
I'm in Tennessee so that could be the problem. I'm getting about 75rpms. I heard that I should be in the 80s, not sure if that was true which is why I thought it could be an engine issue.
