2020 210 FSH Trailer Rebuild
Putting the trailer back under the boat was easier since i could use the winch on the boat.
It did provide some additional clearance for the fenders.
And there is a hair of clearance under the livewell pickup.
I havent had a chance to launch and recover the boat but will update the post when I can formulate an opinion on the slides.
What size wheels / tires are these? I just picked up a set of 205/75/15's, hoping they will fit? Has anyone had any luck with this on the 210 FSH trailer?
I tried the search but could not find anything. I am getting ready to replace my springs this weekend on my tandem trailer, my question is does the hook eye go on the trailer hanger or the equalizer? Currently the slip eye is on the trailer bracket side but I believe the springs were replaced by the PO and I am seeing a few pics with the slip eye on the equalizer. Just double checking before i do the replacement.
Front to back both springs with the slip eye in the rear. Front spring slip eye goes to the equalizer second spring slip eye goes to rear most bracket
I just noticed that I didn’t get these with the kit. Talked to a local trailer place and they said they are not needed to just use the u bolts around the axle. Can anyone verify this would work without them?
I would use them. It will distribute the load of the clamping force evenly. Clamping against the leaf isn't ideal
