TimeOnTheWater07
- Michigan
- SX
Hey everyone. I bought a 2021 SX190 with the Shorelandr black painted/powder-coated trailer back in August. I have a few questions about boat / bow placement and adding boat buckles, hoping for some feedback.
Boat placement/bow roller:
I spent some time last weekend trying to get the boat to sit perfectly on the bunks. No matter what I did or have done, I get a gap up front at the bow roller/winch hook. I have to ratchet it down every time and think it's putting too much pressure on the hull/bunks. The bow eye seems to hit directly at the roller, not under it or over it.
Attached are some pictures of how the boat sits on the bunks from the rear and how the bow roller isn't touching, and the bolt holes for the bow/winch post. Most pics were taken with the winch loosened up, as when it's stored, I don't keep pressure on the winch. The one pic is with it ratcheted down.
I tried loading and reloading the boat at multiple different depths to see if I was backing in too far, but no matter what I did, it never comes up and sits properly.
I was thinking of loosening some bolts and trying to get the bow roller to meet the hull as it sits now. Is that a bad idea? Anyone else have this issue or is this the way it is supposed to be?
Boat Buckles:
I've read a bunch of different posts on this on here, but am curious how many people used the boat buckle brackets to install theirs? I have them, and was thinking of installing using the existing tie-down holes on the small plate and placing them upright to minimize the angle. Will this be sufficient or are the brackets junk? I do not want to drill into the frame. Pics also attached for a better idea.
Thanks in advance.
Boat Buckles:
Thanks in advance.
