2022 255xd additional subs / locations
Trucon01
Pensacola, Florida
255XD
Hi all,
I'm trying to add 2 more JL 10 inch subs to the boat and as you know, with the wake series boats, space is very limited...
I have 2 potential locations, but had questions about each.
OPTION 1 :: Beside the drives seat, near the key...
-- There is only about 4 inches between the inside wall to the outside hull. These subs are 5.90 inches deep. Could I use a 2 to 2.5 inch spacer and still have the subs sound optimal?
OPTION 2 :: Under each of the left and right bow seats.
-- If I went this way, what would be the best method for running the speaker wire on the passenger side back to the console? Under the boat, through the ski locker? Somehow, up and around the bow / nose and around to the driver side? Or straight back to the batteries, in the engine compartment and up the driver's side?
Any help will be extremely helpful!
Spacers work fine, will add some strength too.
Running wire across the bow sucks, I would run wire down each side of boat.
