NJboater
I am going to be installing a new stereo in my AR250 and looking for any tips/tricks others have learned in running the power/speaker/stereo/remote cables. I plan to bypass connext completely with this standalone audio system.
Planned equipment:
1. Fusion RA770 head unit (will go at the dash, utilizing the hole already there from the phone holder that I will remove)
2. Fusion ERX400 remote (will replace the current swim deck remote)
3. JL MV800/8i (planning to put this in the storage area underneath the helm on the starboard side, mounted on starboard OR under the port side rear seat where the battery switch is located)
4. JL M6 6.5" (6) speakers will replace the current speakers
5. JL M6 10" subwoofer to be put under the starboard rear seat
My questions:
A. Can I utilize the existing house battery on/off switch to tap into the power for the amp?
B. If 'A' is true, will this impact the DVSR functionality? I assume no
C. How would I run power cables from the existing on/off switch to the area under the helm? (to power the amp)
D. Is there existing power I can tap into under the helm to wire the head unit? Or is it better to use the power I will run from the battery for the amp and tap into that?
E. Best way to replace speaker wires for bow/cockpit/swim deck and run to the amp (underneath helm)
F. Is adding a third battery (second house battery) as easy as mounting another battery tray next to the existing 2 batteries and hooking up in parallel to the existing house battery? Does this impact DVSR in anyway?
Tl;DR - Need assistance figuring out how to run power/speaker wire throughout the boat from others who have done this and have first hand experience. Photos of your installs are helpful!
Bonus - does anyone know how the existing factory stereo and remote are wired?
Thank you!
Planned equipment:
My questions:
Thank you!
