2023 255XD Fuse location for navigation lights?
Mike in SoMD
255XD
Bow navigation lights stopped working. White tower light works, Connext indicates NAV button is pressed which used to turn on the bow lights. First thought is to check the fuse but owner's manual says nothing about a fuse for navigation lights. Any idea where it would be located? Dealer is 2 hours away, not going to haul it up there for this, hoping to fix it myself. I guess I can take the light itself apart and see if there is power to the socket but was hoping to check the fuse before taking it apart. TIA
On my boat there are two settings for the navigation light switch, one for all the navigation lights, bow red and green lights plus the white anchor light, and another setting for just the white anchor light. I suggest consulting the manual on the operation of the navigation light switch to see if just the white anchor light is on as opposed to all of them.
What did you eventually determine was the issue? I'm having the save problem with my AR250.
Have you tried a voltage meter at the nav light to see if it’s getting power but has gone bad?
Hold in your Settings icon on the Connext screen for a few seconds, it should bring you to a diagnostic screen. From there it'll tell you if the boat thinks the lights are on or not. If it thinks they're on, and they're off, you'll have to look for a burnt bulb or sheared wire.
