MrBubbaGump
- FSH Sport
I just picked up a brand new 2022 FSH 210 Sport and as many of you know the audio system is, lets just say lacking. I have a SeaDoo Speedster 200 that I have a full JL Audio set up that I love so I am building my new set up off of that. So far I have ordered the following:
2 Pairs of JL M6 7.7 Speakers
1 JL M6 10in Woofer - (Still deciding if I want to mount on the port or starboard side of helm)
1 M700/5 Amplifier
1 M400/4
I am still researching / measuring for the following wires if anyone has input or has re-run the front speakers wires specifically. It would be greatly appreciated as I don't want to order too much or worse too little. Because I ordered the RGB versions of the speakers I will be re-running all speaker wire.
60 feet of Marine grade 6-conductor speaker/RGB cable
12 feet of either 2AWG or 1/0 AWG power wire
12 feet of either 2AWG or 1/0 AWG ground wire
2 Distribution blocks one of which will have built in fuse holders
3 feet (1.5ft per amp) of 4AWG power wire
3 feet (1.5ft per amp) of 4AWG ground wire
Fuse holder for power wire
Still debating between the new to be released JL MM105 head unit or the Kicker KMC5.
For those wondering why I chose those particular amps, I plan on adding two tower speakers later so I will be utilizing the M700 to its full potential in the future.
Update: Ended up ordering the JL MM105 Head unit & 2 x Rockville Audio's 4AWG marine amplifier kit, for the price it was worth just buying the kit and tossing aside what I wont use. Still working out how much speaker wire I will need as well as if 3 feet of patch cable will be long enough.
1 M700/5 Amplifier
1 M400/4
