Judge
- Cape Coral, FL
- 275SD
I have a '22 275SD but basically the same boat. I can't say that I feel like I have any steering issues. I also can't say I have made any super hard turns at speed but I have been happy with the steering at speed for the most part. But I also installed the Cobra Jet Super Ultimate AK-19 Deluxe fins and Lectrotab trim tabs before I ever put the boat in the water so we might not be comparing apples-to-apples at this point.For the 275sdx owners out there: do you guys have any issues with hard turns at a decent speed? Mine really struggles. Is it normal for the clean out ports to fill with water? I'm coming from a 222 and there was never any water in the clean outs on that boat. I have a couple other issues: it's taking on water from somewhere, dealer can't figure it out yet, starboard engine shakes and doesn't run as smoothly as the port engine. The boat is beautiful but I'm not impressed with the quality and performance so far.
I am not getting any water into my cleanout ports or very minimal. I was just out today in 2-3 footers in the Gulf of Mexico and when I opened the covers there was maybe an inch of water on them. The backend of the 275 sits so high I think it is very hard to get water to enter through the bottom of the seats and into the inspection port area and cleanout ports. You would have to be doing 50mph and then dropping to Neutral so a massive wave crashes over the back of the boat.
Did you pull your cleanout ports and make sure they were seated properly? I would also put some this lube around them periodically.
I did put a bead of marine silicone around the entire inspection / access area and the water drain on both sides just in case water did get into that area but so far I think very little water gets in there on a 275.
There is a fairly well known problem with the anchor locker drain causing excess water getting into the hull and down to the bilge. @drewkaree and a few other guys posted how to keep water from getting into the hull from a poorly installed anchor locker drain allowing water to come in from outside the bow and leaking into the fiberglass in the anchor locker and down to the bilge.
I was going to put in the stainless steel fitting like they did but my plastic fitting was in there very tight and would not come out unless I would have completely destroyed it. Yamaha must have put it in with 4200 or 5200 unlike some of the boats. All I did was take a little 5200 and put it around the hole they cut in the fiberglass that was exposed inside the anchor locker and I put a little more around the drain port on the outside of the bow.
I have to say my boat has been fairly water tight after 25 hours of use in the first month. I was a little worried because I installed a Garmin Chartpotter and had to cut a 1/2" hole under the swim platform for the transducer. Then I drilled 18 holes through the transom to install the trim tabs and another 6 holes in the bottom of the swim platform for the actuator mounts. I did this all before putting the boat in the water so if I had a lot of water coming in I wouldn't have known if it was my trim tab install or something else from the factory.
One place I know a fair amount of water could get into the boat very easily is the four cup holders on the swim platform. When I pulled two of them out when I was getting to run the cables for the trim tab actuators, I could see Yamaha did a very crappy job sealing them. I pulled the other two out, removed the terrible sealant job Yamaha did and resealed them with 3M Marine Sealant. If I didn't pull the cup holders and reseal them, I'm sure I would have been getting water into the bilge.
Yamahas design for letting the cup holders drain when they fill with water.... and they always do.... is also terrible. They drilled four holes in the bottom of the swim platform and then shot in a boatload of 4200 until it formed around the bottom of the cup holders. Then when the 4200 dried, they tried to drill a hole through the bottom of the cup holder opening through the 4200 and out the bottom of the swim platform. The 4200 keeps re-sealing around the holes they drilled and the water never drains out of the cup holders. I bought a large upholstery needle on Amazon to poke through the holes. I can push it all the way through the bottom of the cup holder and out the bottom of the swim platform and when I remove it, the elasticity of the 4200 seals the hole back up so the cups won't drain when they fill with water. I may try to pit some 3/16 - 1/8" tubing through the 4200 to allow the cups to drain. If Yamaha didn't do a good job adding enough 4200, you could be getting water in from the bottom of the swim platform or from the cup holders draining into the transom.
As far as the engine shaking.... it could be an engine issue but I would also ask them to check the alignment of the shaft from the motor to the pump.
How are your engine RPM's? Do both engines accelerate evenly in single throttle mode? Do they both hold the same RPM's at idle and at speed?
