Banditgrrr
 - Las Vegas, NV
 - AR192
Went to the river yesterday and had performance issues (or at least I feel like there were). At max throttle, I was at 7100 RPM and topping out at 41 MPH. Does this sound right?  Here's the relevant data. Just looking to know if this speed/RPM sounds right or if there's something I should look for.
1. Water was pretty flat
2. Air temp was 107, water temp was 71
3. In the bow: 1 adult (150 pounds), 1 kid (60 pounds). In the rear: 1 kid (50 pounds)
4. I upgraded to an SVHO and added a 2nd pisser for water flow
5. Impeller and wear ring seem to be good with no obstruction
6. Replaced the seal on the clean out plug 6 months ago and seems to be seated fine
7. Noticed there's about 8" of water in the ski locker but no idea how it's getting there. Relevant just because this would be extra weight.
8. Made sure that nut is adjusted on the throttle cable so there's maximum throttle
9. Bimini top is open for shade
10. I was headed down river so the current was with me, not against me
Could there be anything I'm missing? I would think I should be at about 7700 RPMs which would give me a few more MPH but also I'm assuming I could be wrong and 7100 rpm's and 41 mph would be normal in this situation.
