Wesley Cobb
- 242 Limited S E-Series
I have a piece of foam loose in the engine compartment. I want to stick it back to the hull where it belongs. Everything I have used up to this point has not worked...it either soaks into the foam or doesn't adhere to the uneven fiberglass hull surface. Any advice on what to use?
