Beachbummer
- Houston TX
- SX
Hello folks,
I realized through last season that my starboard TPS needs to be adjusted. No wake will activate only if I lost the idle way down, below 1550.
I have explored and actually removed injectors before but even with the service manual it has been somewhat haphazard.
For those of you that have successfully removed and reinstalled the throttle body, what are the tips that you wish you had known before you did the job?
I really don't see much access to adjust the tps without removing the throttle body. Is this right? Is there something I'm missing that might allow you to adjust TPS while the throttle body is still installed?
Thanks in advance for your knowledge and insight.
