Welcome to Jetboaters.net!
I had the dealer install a new aerator. It doesn't work, I checked the fuses by the batteries and they are good. Any other suggestions? Thanks! They did test at the dealer and was working after install.
Then you will have to use a multi meter and see if you have power to the line side of the circuit breaker and trace back from there. In the back of the service manual there are wiring diagrams….
