AR210 helm seat
Chris5105
Westerville, Ohio
Does anyone how to remove the helm seat from the pedestal? My helm seat will only rotate about 45 degrees. There is a peg on the pedestal and a notch on the seat base that will only allow the 45 degrees of travel. I've tried unscrewing the peg but it just spins. I'm thinking if I can get the seat off I can get down in the pedestal and maybe remove the peg.
@itsdgm has some pretty detailed photos of the seat base and how to take it apart. I'm sure he'll be happy to post them for ya!
Well I did change the seat pedestal on our 2007 AR210. I believe that I was made by Garelick. Here's the best that I can remember about swapping it out.
Just to let you guys know. When I purchased mine I discovered that Garelick makes two different adjustable seat posts that are 12"-17". One has an indexing feature that has a locking pin which secures the seat in 1" increments (http://garelick.com/productribbed.php?pnumber=75635), the other just slides up and down for adjustment (http://garelick.com/productribbed.php?pnumber=75535). Both are then locked down in place with a hand tightening knob.
I ordered the one without the indexing feature, but only because I had an Overtons gift card and that's the only one that they sold. It seems to work great.
Mine was an easy swap out for the original, the only thing that I had to do was drill a hole into the new pedestal for the bolt that limits the swiveling of the chair.
Here's a few pics of the old one and the new pedestal in place.
File comment: New Pedestal Extended
How to change it out.
My bolts were easy to remove. The "nuts" must be embeded in the boat somehow. Either there's a plate mounted down there, or "blind nuts" in place.
First I removed the seat from the old post by removing this bracket. Then the seat just lifts off the pedestal.
Then I removed the Pedestal from the boat by removing the bolts at the base.
Next I removed the bolt that limits the rotation of the chair, and pulled off this plastic bushing.
Then I positioned the new pedestal so that the handle was easy to reach when installed in the boat and drilled the new pedestal to fit the swivel limiting bolt in the correct position.
Hopefully this has the information that you're looking for. Please feel free to contact me if there's any information that I left out.
@itsdgm FYI....your images will only appear for someone who is logged into both sites and Brian has locked down the member tips section to only members who are logged into YJB :rolleyes:
Another controlling move....
So you will want to copy your images here if you want members here to see them.....sorry....Freedom lives here....but not everywhere....
I plan on working on this tomorrow because I want a seat that rotates 360 degrees
Thanks for the advice, I'm nervous to take the pedestal base from the deck, looking for an option that does not involve that. Seems like my seat design is rare. Because I haven't heard of many people having my problem.
So I'm not just dumb, does the seat really only rotate 45 degrees on the 2014 212x? Seems dumb and I swore I read somewhere it was supposed to do 180...has anyone else found a fix for this besides replacing the pedestal?
Edit: I just read the manual and it says it should rotate 180...but for the life of me I can't get mine too, seat all the way forward, all the way back, same 45 degree rotation.
@Master-Spud I'm not sure if yours is the same design as mine in the pics above. But mine used to be limited to about 45-90 deg rotation due to the seat hitting the side of the boat on the throttle control side and it hitting the limiter on the deck/open side. It didn't make sense to me why it wouldn't rotate all the way around so that I could face the rear of the boat and at the very least the center table. I easily corrected this by unbolting the base (6 Phillips head screws) and rotating the base counter clockwise 1/6 of the way around until the base lined up with the screw holes. This enabled the seat to swivel further in the CCW direction. Not sure if your set up is the same though.
No problems with the screws holding after removal and being reinserted? Might give that a try, seems like an easy thing to try at least, not confident it will fix it.
No problem with mine. It's been a few years since I've done this one but I do remember having the same concern as to how they were secured below. It seems that Yamaha must either have a metal plate down there or there's "blind nuts" embedded in the floor.
Good to know, I'll give it a try, really annoying not to be able to swivel and relax with everyone while floating
I know this is kind of old now, but I was looking at how to get that screw out, were you able to remove it @Master-Spud?
Here's what my seat looks like for reference:
unscrew the base from the fiberglass and rotate it 90 degrees or so and you should be able to rotate it almost 180 degrees. I did it on my last one.
Yamaha mounts the base so that the seat will only rotate to the left 45 degrees, so that the back of the seat if rotated all the way wont contact the throttles potentially causing a safety issue. The seat should rotate 180 degrees, just 45 degrees to the left and 135 to the right. Just dismount the base and adjust to your liking.
I haven't actually done it... On my list of things to do... It just keeps getting pushed down the list
I think you can just pull the seat off the post once you loosen the knob that tightens the seat to the post that prevents unwanted swiveling. Then you can remove that limiting screw. I just did it on my boat.
I did it this weekend, and you are right @Rideitout. Simply loosen the knob that tightens the seat and pull it up. I had to swivel mine towards the middle of the boat and wiggled it a bit and it came right off. There simply is a locknut on the inside keeping it in place.
