Osric
 - 242X E-Series
The center ballast bag on my new 242XE seems to have developed a leak - the seal around where the quick disconnect fitting is does not stay flush to the fitting - and looking at the center tank it looks to me that if I plug the drain fitting I can just fill it as a hard tank.
Has anyone done this / are there any issues with doing it? Or alternately, is there actual proper documentation for the ballast system anywhere? I am fairly sure that I have no info at all on how to use or calibrate the system in any doc from Yamaha.
Thanks!
Thanks!
