Bunk lube
Noko
Lake Nokomis Wis
My boat goes in once a season and come out once. I've never lubed the bunks in 10yrs but thinking of maybe doing it this time. My boat sits on the trailer in a heated building for almost 9 months so I think it gets a little sticky. We backed the boat in today and maybe too far and the trailer floated, so maybe a little sticky. Any thoughts about lubing the trailer? I looked up on here and the web and silicone and other products were mentioned.
I use this Slydz-On it works great.
I’ve researching this issue because our boat seems to stick to the bunks, even when launching. I had the Ultimate Bunk Boards on my old boat, but wanted to the carpet bunks a shot before I swap them out. I’ve read where others use silicon or other spray on products, but decided to give Gulf paraffin wax a try to next time we go out.
Thanks! Heard the same from a few sources but I trust the info here more.
Talked with my friend this morning about your issue, he thinks that your bunk carpet could be dirty, he suggested your bunk carpet may be contaminated and that you should take the trailer to the coin operated car wash and clean the bunk carpet thoroughly.
You don’t have any bottom paint right?
Mine gets stuck at the front of the front bunks where it’s most angled so I’ll spray that area and anywhere that I see wear marks on the carpet with regular silicone spray once or twice a season and it does the trick.
I don’t want it too slick so I’ve never tried one of the dedicated products.
From what I’ve read, keep the winch strap on your boat when launching and go easy on the throttle during recovery until you have a better sense of what to expect. I’d also appreciate hearing about your experience. Good luck!
Your trailer "floated?" That's a new one for me... I've always go in deep enough to see the boat start to float. Then a bit more to watch the boat get level with the water, then slightly more giving the boat a little bump with the bow roller to push back. At that point my wife and daughter have the boat by the bow and stern ropes, and I can slow roll the trailer up the ramp.
According to my wife who was watching the boat as I backed it in, yes. I've never had this happen before. Probably dirty bunks that others have mentioned.
Thanks. I'll clean it. Got some Slydz On.Thanks to all for the info.
I also occasionally do the silicone spray on the carpet bunks. Definitely keep the strap and safety chain on, it makes a huge difference.
In this case you really ought to keep the winch strap tight aa well and then just unhook the hitch. Take the trailer out for a spin to show it what it’s been missing!
It's just a treat for everyone, and I think the trailer looks forward to it myself 😂
So update, I pulled a good boner. My wife said the straps were not undone and thats why the trailer floated. We had another couple point it out as we were launching.
LOL okay, that makes sense...
At pre launch, do The Jet Boaters Cross:
- left transom strap unhooked
- right transom strap unhooked
- ladder up
- transom plug in
I recently applied silicone spray to my bunks. Huge difference! I used to put the trailer in fairly deep, but I would still have to use a lot of throttle in reverse to get the boat off the trailer. As mentioned, leaving the winch strap and safety chain connected are a must. After I back in the trailer, I unhook the strap and chain and jump on the bow. The boat then slides off the trailer and basically launches itself. Also, it takes much less effort to winch the boat up after loading.
