Bushing for Steering Connection - anyone have a part number?
Pokeyt
Does anyone have a part number or source for the nylon inserts that are part of the steering connector? I'm assuming I can figure something out in the small parts bins at a hardware store but a specific part would be helpful.
My boat is an 05 SX230.
@Bruce has 3D printed replacements. Might need to confirm with him they will work with your model.
If Bruce is still making them, I'd go that route, but as my memory goes, I sourced stainless steel bushings, and drilled out the holes to the next english sized bolt, which I believe was 1/4". I don't necessarily regret doing it how I did it, as the hole in the jet nozzle flange was slightly worn out of round anyway, so drilling it open a little bigger got it back to a perfect circle, and removed any excessive play.
I am still making them.
Initially I went with aluminum bushings that I drilled out the inner diameter of to make them fit. They worked well but were expensive and time consuming. I decided to try printing them when a member was having trouble printing. I was able to get a more precise fit with the plastic part. The top washer section does have a tendency to separate from the tube in use. This does not seem to change effectiveness. It might be a slight improvement. Otherwise the plastic ones hold up well. I grease them inside and out.
