Shack
- Lanesboro, MN
Took out our ‘20 ar240 today. Cruised around a bit then sat and hung out for about 4-4/12 hours, radio on quietly. Went to start the engines, port started fine starboard wouldn’t start right away checked clean out hatch (probably had nothing to do with it) went to start again and it took a bit then started. Right after it started I get a check engine warning but everything was running fine so we headed back to the ramp (about 5 minutes). Got it loaded up, started both engines to blow out the water and both started right up and no check engine lights came on. Got home flushed both engines on the hose. It ran great and no alarms as well. Both voltage were 13.8-14 on the way back. We went slow. Any idea what happened??
