71BeaterBoat
- Southern CA
I'm the new owner of a 2007 AR230 that has needed a little bit of work to get it water ready for the next season. The first major project I tackled was replacing the wood inside of the deck hatch on the swimstep over the clean out ports. When I inspected the boat before delivery I noticed that the starboard side of the hatch was solid, but the port side was incredibly spongy and had a lot of give on it.
Once I got the boat home I started out by removing the hatch from the boat. After I took the hatch apart I realized the damage was a lot worse than I had expected. The hatch is basically comprised of 3 parts: the tray that is the top of the hatch that you walk on, a wood inner core, and a fiberglass bottom that is meant to seal the bottom to the top and make it waterproof. Unfortunately a crack in the hatch and no sealing inside of the holes for the latches allowed water to penetrate into and rot out the wood core. The wood was entirely missing on half of the hatch. Because of the rotten wood, I had to replace the core of the hatch and rebuild it. The part is discontinued by Yamaha and so unless you can find a used one or from a salvage boat, rebuilding is going to be our only option.
I'm confident that this hatch is waterproof and will not rot like it did previously. I believe that the marine plywood added substantial weight to the hatch, but it's hard for me to compare because 1/2 of the wood was missing from the hatch when I took it off the boat. The hatch appeared to have been built with end-grain balsa wood core from the factory, I don't know if that would be a good replacement core or not due to the rotting that I saw.
Here are the products I used:
Here are the steps that I used to complete the repair. To begin with, I'm not a professional in this area and this is most likely not the best way to accomplish this. However, it worked for me.
- 1/2" Marine Grade Plywood (No local lumber yard carried 3/8" which is what the hatch actually needed)
- West System 105-B and 205-B epoxy resin system with metering pumps (I ended up using about 75% of the gallon)
- acetone
- fiberglass mat
- 2x3 wood boards, 8' and 4'
- Remove the hatch from the boat
- Remove the latches and support for the gas piston.
- With the hatch supported, use a small grinder or cut-off wheel to cut along the inner border separating the top of the latch (what I called the "tray") and the bottom fiberglass layer.
- Once the fiberglass bottom and top layers are cut apart where they intersect, I used a long screwdriver to pry the bottom fiberglass layer from the wood. (This caused some damage to the fiberglass and at least 1 layer of mat was removed in some areas where it was still bonded to the wood.)
- Using a metal scraper I was able to remove the rest of the wood from the tray.
- I then sanded the remaining wood until it was level, I wasn't concerned about removing all of the wood to fiberglass. If it was still bonded to the fiberglass I didn't want to damage anymore of that structure than I needed to.
- Use acetone to clean them fully.
- I used the bottom piece of fiberglass as a template to measure and cut the marine plywood.
- Use wax paper on the outside of the hatch fiberglass pieces to cover the holes where the latches go through and secure it using painters tape. Lay the tape as the edges of the hole so that it creates a solid seal around the hole. The less resin intrusion onto the outer layer when you pour it the better.
- 1 layer of resin on the top tray
- 1 layer of resin on the bottom fiberglass
- 2- 3 layers of resin on the marine plywood to fully seal it, making sure that there were no dry spots after the second layer, and using the 3rd to create a smooth surface.
- 2-3 layers of resin on the exposed edges of the plywood to fully seal it.
- Fiberglass mat and resin added to the areas of the fiberglass top tray and bottom piece where fiberglass was removed during the deconstruction of the hatch.
- Resin layer on top of the mat/resin layer to build it up.
- Sanded the top and bottom fiberglass structures until smooth, making sure not to sand through to the mat.
- Test fit of the sealed plywood into the bottom tray and sand any points of conflict due to the added resin thickness.
- 1 heavy layer of resin inside of the tray, then I laid the plywood into the tray.
- using (2) 2x3 boards along the length of the plywood on the edges and one perpendicular in the middle clamp the plywood down into the tray with even pressure.
- Once the resin in step 19 is fully cured, fill the outside border between the plywood and the tray with resin until it is full. This may take multiple batches and applications of resin. Once this resin is cured, the tray and plywood core should be 1 solid piece without any gaps or holes.
- Heavy layer of resin over the plywood and then position the bottom fiberglass piece in place and repeat the 2x3 supports and clamping that was used in step 19.
- Layer of resin around the outside of the bottom fiberglass to bridge the plywood to the fiberglass smoothly.
- Sand the bottom layer to tray lip smooth
- Cut 2 1/2" circular hole for the latches.
- acetone to clean holes for latches
- 1-2 layers of resin inside of the holes for the latches to make them waterproof.
- Sand the holes smooth without sanding through resin and test fit latches.
- Paint bottom of hatch as needed.
