Mainah
- Chapin, SC
- Boatless
- NA
- Other
- Other
So as many have posted their bilge is not always dry after a day on the water. In the process of doing some other mods I discovered cup holder drain lines had come off, the drain line for the bilge hatch was pinched and the through hull fitting for it was only finger tight. I fixed the isuue by installing new cupholer drain lines using surgical tubing and new through hull lines using ballast hose. I applied new silicone everywhere something pieces the hull. The result. I also have a new garboard plug with slightly larger O ring. The result ... bone dry bilge!
Those cup holder lines in the swim deck are a joke and secured with tiny zip ties. Well not so secure but surgical tubing fixed that.
