Welcome to Jetboaters.net!
Good stuff gentlemen. Too bad the BEP crossover voltage isn't programmable. Even an AGM house at 12.8v volts would risk cooking an FLA start a little bit since that is also the BEP cut out voltage for the bridge.
I wouldn’t worry about that with an agm battery… the voltage cut out of the dvsr is 12.8 v I think I said 12.7 above, so it would not take much for the voltage to drop to the cutoff and the pick up voltage is 13.4v.. so its totally fine with any lead acid battery set up.
Agms don’t have the equivalent storage capacity as Fla batteries…. Save your money and buy the Fla batteries. Your best bet is an Interstate Fla battery….or a Sam’s or Costco one, that’s the best bang for the buck.
