knoxboatin
- Knoxville, TN
I have an AR-210 with a three-way battery switch. Bilge is wired to battery #2 directly, the engines, display screen, lights, etc are all wired to common off the three-way switch. We have found if we run the switch on battery #2 (same as bilge) we have no problem driving the boat around. If we run the switch on battery #1 (so console display and everything on a different battery from bilge) we end up getting an overheat warning on Starboard engine after 10 min or so of driving the boat. (Oil is full, pissers running fine flow of water, the boat is a 2021, no apparent overheat.)
My theory is that somehow the console electronics get confused if they sense a voltage difference or something between the two batteries, and throw an alert that is mis-interpreted as a starboard overheat. I'm guessing this because the console would have a live connection to both batteries when the switch is in battery #1 position since it has a bilge control switch.
Last year the boat was new and only had an on/off switch and two batteries wired in parallel. Never any problems. A tech from my dealer did not like the setup so this spring he put in the three-way switch for us. Another data point is if I run with battery #2 disconnected and the switch set to battery [HASH=108]#1,[/HASH] everything is fine boating around.
I wanted to use the two batteries as independent options to run the boat. Based on what is happening, it looks like I need to use battery #2 for running the boat, and battery #1 as "house" or maybe just as a backup in case I run down battery #2. Is my theory sound, has anyone run into this on a recent model Yamaha? I validated yesterday about an hour of runtime on battery #2 driving around, all was fine. Last weekend I was trying to run on battery #1 and I got the overheat error and crawled into a rat-hole trying to troubleshoot it and worrying about it. Maybe this post will help someone else. I'm now carrying an infrared thermometer too but got no overheat error on yesterday's outing.
