Stereo Exile 800.4 , 4 Channel Amplifier
CFD3Captain
Coshocton, Ohio
Moomba
Wake
Selling my Exile 800.4. It's a great 4 channel amp (200x4 @2 ohm and 125x4 @ 4 ohm). I ran it bridged and it pushed my towers (bridged 400x2) with no issues. My OCD has gotten the best of me and I'm upgrading to match my Exile Javelin Amp. I will post some links with info for it.
Would make a great upgrade for the guys with Polk DB's as stock.
Asking $240 shipped
Thanks!
https://www.wakemakers.com/exile-xi800-800w-4ch-amplifier.html
Still have it....
The hardest part will be hooking it up to your battery. I am assuming it is towards the starboard rear.....? You will either have to run long power/ground cables or long rca, remote turn on and speaker cables. The latter option being the cheaper usually. There are plenty of threads on here for a DIY install. Here's a thread I found with a quick search....
https://jetboaters.net/threads/amp-install-speaker-wiring-question.1636/
Actually it's at the port rear. Assuming that I can run the cable from the battery to the amp with no issues, I was just wondering then how it hooks up to the head unit? If I have to do each speaker individually then I'll have a professional do it. If it's easy to hook up then I'll do it. I have 6 speakers, is the amp powerful enough? Sorry, I just don't know much about this stuff
I originally had 2 of these amps, one for the towers and one ran 6 cabin speaker's. Yes, it was a nice boost to the volume/sq. The link I posted shows how you can jump to the speaker wires as they go into the headunit. Lots of resources online to show you how to do this. Then you just need to run a turn on wire from the headunit to amp and the power/ground. It seems like a lot when you've never done it, but once you get in there and see everything, its not so bad.
We stopped at saugatuck dunes on our way to Grand Rapids boat show last Fed. Looks like your photos. Yes no snow last year in Fed in MI.
I think you're posting in the wrong thread LOL
:banghead: You are correct sorry.
