Boat Stuff GPS Antenna Cover Replacement - White No Logo
  • Thread starter Thread starter Bruce
  • Start date Start date
  • Quantity Qty: 948
This is a replacement cover for Yamaha part number F2D-U8K1L-00-00 also known as SANAV part number GM-88U.
It is a new design that includes an optional external seal. If you do not wish to use the external seal it is recommended to use silicone caulk to seal between the plastic case sections and around the heads of the screws. It is printed from PETG plastic which should hold up well to sun exposure and resist impact.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
Other colors are available at 3D Printed Parts. For those that want show support of the forum the GPS Antenna Cover Replacement - White JetBoaters.net Logo is $5 less at $20.
I think the gps antenna only facilitates mph. If this is true is the alternative solution to install an aftermarket depth / fish finder with a speed pickup wheel/pitot or use a third party app like navionics.
fyi I just sold the gps unit from a wrecked 2017 I bought. In addition to not being available from yamaha when they are available yamaha charges $300 + for them. ridiculous !!!
Thank you … this is what I have
Bruce as soon as I find a replacement, yes … I will send it to u
Thanks, I would like to use it to take a look at modeling a smaller cover set.
Initially I replicated the original cover but I think it is larger than it needs to be.
Hello, i just want to confirm this stills been made, i just placed and ordered. I actually need two. I dont know if i should place the second order and just get one shipment? Let me know…
Btw this is how mine looks
Yes, your cover will go out on Monday. Place another order for the second. I send them in padded envelopes. May ship separately unless I have an envelope big enough for two on hand.
I just ordered one. Do you still make these? It didn’t give me a color option so hoping it’s white.
I am shipping a white cover with the JetBoaters logo. There are different ordering links for different colors and designs.
Thank you for the prompt reply and shipment!
Got my base and cover but now I’m not sure how to reassemble. Here what I have including the old broken one. The only thing I know is that the little screws (bottom right) go through the circuit board. Can anyone help with the rest?
The four little screws secure the circuit board to the base.
You need to cut and splice the black ground wire. A crimp butt connector or small wire nut will work.
The four larger screws secure the bottom of the case to the top.
The two long threaded rods have brass nuts on the end that need to be removed then use the ends of the those rods that the brass nuts came off off to secure the case to the boat.
The black seal goes under the cover to reduce water intrusion.
