How I Replaced Yamaha's AIRMAR Transducer for half the cost (WITH PICTURES)
Wanted to let people researching know that I ended up getting a bad replacement transducer. The third one fixed the issue. The second one would throw the N2K error at first, but would then be fine except the depth was way off. So it is possible to get a bad one from the start.
I am struggling with this very issue on my 2020 242 SE. Lots of com errors. When I disconnect the transducer, the only issue remaining error is the transducer. When I reconnect all the errors reappear. I am still going to test the connections prior to replacing the transducer, but after talking to a local service tech, I am 95% certain that it's the transducer. FYI the transducer was replaced two years ago.
I found this Garmin/Airmar DT800 on Amazon. Will this do the job? Anything else I need to know? Should I just splice or is there a pigtail out there for me someplace? Appreciate any help.
We will have a pigtail plug and play for sale by the end of the year.
I have a 2020 SX190 and my connext screen has been showing crazy water temperature numbers...106-108f. Is this the beginning of the end for my transducer? Everything else works fine, including depth and speed.
I want to thank you for this. I have a 2019 242 limited s e-edition. I did just what you said and it worked perfectly for a fraction of the cost and no wait time at the dealer. I ordered the airmar transducer from Hodges marine and then the nema connector from Amazon. Removed the old, spliced the end from the old to the new nema connector and installed. All worked as it should. Biggest issue was removing the muffler on the starboard engine so I could easily get to the transducer thru hail location.
TL;DR - I saved about $250 on a single item when replacing the defective AIRMAR transducer in my Yamaha jet boat with an equally valid but "non-OEM" option.
Hopefully this helps someone... In my 2015 242 Ltd S, the transducer went bad. Read about how I came to that conclusion via this post.
This particular post is to document how I replaced my Yamaha transducer (F2D-U8K1W-01-00) with an identical AIRMAR transducer for half the price of the Yamaha OEM part. (Retail $697.99, Boats.net currently $505 and backordered with no estimated ship date available)
Bought this AIRMAR DT800 transducer for $263, shipped. This proved to be identical to the one in my boat, minus the connector difference. The Yamaha version has the connector that connects the transducer seamlessly to the house umbilical wiring, providing N2K connection thru the SPU to the Connext system.
In case you are wondering, NMEA 2000 wiring is as follows. This corresponds to the pinouts on the Yamaha connector for the AIRMAR transducer, except there is no pin for shielding. My supposition is that Yamaha decided to not implement shielding in their minor N2K backbone.
Red—Positive Voltage
Black—Negative Voltage
White—NMEA +
Blue—NMEA -
Bare—Shield
I did not want to void the warranty of my brand new transducer by cutting the end of the cable off, so I created a pigtail by lopping a foot or so off the prior transducer cable, and buying an N2K patch cable off Amazon. This cable cost me $22.57 shipped, Amazon prime. Add some 3:1 heat shrink adhesive tubing and some marine tinned copper crimp connectors w/ 3:1 integrated heat shrink adhesive tubing, all of which I had in shop supply from prior boat projects, I have about $25 invested in this pigtail. The final pigtail is shown here. The build photos follow.
First, I dummy proofed my cutting by attaching the new N2K cable to my new transducer. Shown below. Again I totally could have lopped off the end of the new transducer cable and spliced in the Yamaha connector directly, but that would have voided the transducer's two year warranty. I would rather spend $20 to have a pigtail that allows me to just screw on a new transducer, than have to ever do this connector splicing game again, and likewise lose the transducer warranty.
I then proceeded to lop off a foot of cable from the old transducer, and likewise lopped one of the ends off my new N2K cable from Amazon. Cutting open both cables, you can see they are each color coded for easy wiring. Nice. Again, I provided the details above in case you require further troubleshooting, but you could have done this wiring without knowing red meant DC+. Red goes to Red. Oh well, I like to know how things work.
I spliced them together, and heat shrinked them.
Connected to the new transducer, and tested in the boat. Worked great. Depth comm error went away, got a temp reading, and low depth alarm. Good! Considering I have the transducer still sitting on the floor of my boat..
Another
Heat shrink tubing over top... 1/2" worked for me.. I put the 1/2 inch tubing on each side of the pigtail wires before splicing, as they would not fit over the connectors on either side. (Do this BEFORE you wire it up!). The last piece was a 3/4 inch tubing that I placed over top in the end to seal the two 1/2" ones together. I found it useful to step up in sizes of heat shrink even though I'm using 3:1 due to the way I did the connections being so much larger than the cable diameters.
Final complete kit:
BTW, here's a pic of the new transducer:
And the old:
This is awesome. How hard is it to get the old transducer out?
I have a 2020 with the same problem. How hard is it to get the old transducer out?
It is in the rear compartment, you need to remove the clean out tray and possibly unstrap and move over the water box that in near the center on the boat. It can be done without moving the water box but its a stretch
I will have plug and play harnesses available for this swap in the next two weeks.
No worries!
- I did do the pigtail adapter. I spliced in the old Yamaha connector onto a new one from amazon. I did read somewhere on here that there was a pre-made version available, but I saw that after the fact.
- Connector was on the starboard side engine bay, up on the wall with a bunch of others. Only had to fish through the rear wall of the engine bay into the bilge. The new transducer came with plenty of wire on it.
- I didn't calibrate it yet, too lazy :). But the depth isn't far off enough to worry about for me. You'd have to know the depth and calibrate it that way. Maybe in a pretty shallow area with a tape measure?
- I did remove the tray, it wasn't too bad. Also gave me the chance to reseal it up since the factory sealing job is pretty lousy. I had to use silicon spray lube and a heat gun to get the drain tube off of the tray but the cleanout ports weren't bad.
Thanks for all the info! Getting ready to knock out this project this weekend. In regards to your bullet point. Is the factory connector difficult to find on the wall with all the others? Am I looking for something particular?
Our T-harnesses to make this a plug and play install are now for sale!
I had the same exact issue (2022 ar195s).... AND I replaced the Transducer with the DTS810 ....twice. After lots of pain and suffering and focusing on the wiring harness.... it turned out to be another device on the NMEA CAN.... the Radio. My suggestion to anybody with this issue is to pull the NMEA Line off the Radio.... there is a good chance that the Transducer will come up. When I pulled my radio out (mounted on the Rear swim deck) the entire back was full of Rust. New one on order. Good luck.
If anyone needs the transducer for a 19 foot f2k-u8k1w-00-00
I have one new in box Id let go of for $150. No splice needed. This is the Yamaha one.
I found a substitute Airmar Transducer for my 195S model year 2021 that works great. The Yamaha P/N is F2K-U8K1W-00 but if you tried to find one recently, you know the exact replacements are simply not available. Yamaha cannot provide a date for availability. There are great ideas in this tread for substitutes but I cannot find anything for my specific boat model and year.
The OEM Yamaha transducer in this model is a IDST- N2000 and has a paddle wheel to measure speed. Interestingly, I found that the speed comes from the GPS sensor not the DST transducer. I cannot determine that the paddle wheel provides any value. Accordingly, I bought the DT-800 (depth/temp) transducer (without the paddle wheel) as mention in an earlier post. I also purchased the NEMA 2000 adapter cable mention in the same post. In lieu of splicing the adapter cable with the Yamaha connector from the original failed transducer, I purchased the Yamaha connector model number Deutsch DTM04-4P and the associated pins. The pins were crimped into the adapter cable and inserted into the body of the DTM04-4P. One end of the adapter cable plugs into the new transducer cable and the other end plugs into the socket-end of the Yamaha connection in the engine compartment. The DTM04-4P is easy to assemble without any splicing. Even though it was reported earlier that the DT-800 is a substitute for the K2D-U8K1W-00, i can confirm that it also works as a substitute for the K2W-U8K1W-00. Temp and depth reported from the substitute transducer is accurate. Total cost was less that one half of the Yamaha Price and it was off the shelf. Best of all, the annoying alarm sound is gone. No longer have to frequently reset the alarm. Hope this helps those of you that have a 195S.
Hello,
What symptoms you have for the issue?
First time out this year. I have no speed read out and no navigator😞 everyrhing else works ok in Connext.
I had similar issues that were resolved when I replaced the GPS antenna.
I’m going out this weekend. If same issue then I will go deeper troubleshooting. This forum is really big help for newbies like me. Thank You
