Shape2001
- 242X E-Series
2016 242x 100 hours
Had the boat out last weekend. Everything was perfect.
Left slip in a hurry and did not realize I left keys in the ignition and in ON position.
House/start battery switches were also on. Stay and house plugged into Noco. Stayed that way for 6 days.
This weekend batteries were dead. Shut off both battery switches and ignition and left on Noco. Waited for a few hours.
Turned on house. Put in key. Turned key and no boot sequence of connext system. Turned on start and house and connect did boot. Batteries were both reading 11.x V.
Engines both crank and come close to start but neither will fire. Tried to jump using portable jumper battery and using parallel switch. Getting powerful crank but no ignition.
checked lanyard and clean out kill switches. Engine will not crank with lanyard out or hatch open. With lanyard and hatch button pushed manually or with lid the engines do crank.
Charged again overnight. Reading 12.8V on each. Same issue. No connect boot of house. Strong crank but no start. I tried factory reset. I swapped batteries. I cleaned all terminals and connections. I checked all fuses I could find. Somewhere there is a failure in the system. Not seeing any error codes or warnings
I think everything is related to my inability to boot connext from house battery alone. I never needed my start battery on to boot connext system but now I do. There must be a relay or fuse or something zapped or triggered that is not allowing me to boot connext off house alone and also not allowing my boat to pass all the checks to allow engine to fire.
Any ideas to help solve this mystery much appreciated!
