dan144k
- Palatine, IL
I have had my impellers on and off several times.
I had sent my port Solas impeller to Impros to get it adjust for a little more low end power, was cavitating bad with weight in the boat.
Went to remove stock impeller (only been installed maybe 4 months) and it was a lot more difficult than in the past. Once apart I found the impeller female threads damaged and also the shaft had damaged male thread. I always used the locktight 567 on the threads like the manual directions show.
(in the future will use a never-seize- I think)
Question:
Anybody know if you can replace the shaft easily?
Does it just slide inside the bearing in the pump housing?
Also, boat is still under warranty with Yamaha.
I spoke with Yamaha service manager and sent him pictures.
He said he would check for me.
I mentioned to him it was a threaded serviceable part and should be able to unscrew without gouging things.
Waiting for a reply, figured I would try.
Question:
