Tonkatoy
- Glendale, AZ
- FSH Deluxe
I like my boat.
Believe it or not.... I set time aside today to address the anchor drain issue and the MASSIVE livewell leak(s). First off the anchor......to my surprise the grommet was actually placed correctly and long enough to pass all the way through. Tested it and no issues.
Siliconed the hell out of the live-well and gonna see how it does tomorrow
Pull your 5gal storage on the rear deck and you will easy access to all of the livewells intake, and drain hoses. It was where they connected I found massive leaks.Shelby,
Where did you find the leak at in the livewell? Mine had a silicone o-ring laying in the bottom of it, when I got it and the service guys said it was just some trash that got left in there... Would be nice to know if that's what is leaking.
Thanks. I'll see if I can adjust the latches, first. I had thought to do that, earlier, but had forgotten about it, until I read your post. If that doesn"t work, I will resort to the new seals.Once you close the hatch, and turn the handle to close it, theoretically, the seal should keep out the water. That is, unless you open it while there is still standing water there and it sloshes into the compartment. What I have found is that the tolerances are pretty lame coming out of the factory so if you push down on the lid after you close it, you'll hear and see the lid doesn't really close to its highest tolerance, locking out the water.
Before you try another type of sealant, have someone spray down the deck while you sit in the changing room. There's a little opening just above and on the port side of the boat where the trolling batteries would normally go. Water that goes into the storage compartment is meant to drain down that route and into the changing room where the drain at the bottom can take it to the bilge. If you see water coming down, then it's obviously not closed well. Then you can go ahead and adjust the latches from inside, get a tight closure, and try spraying it down again. It's a weird design. They should have had the water bypass the changing room completely and go aft to the drains by the console. View attachment 67553
I hope it works. I'm always finding things on this boat I didn't know were there. Like the drain from the storage area into the changing room. At first it was the anchor drain, then the drain plugs, and now the scupper that drains into the room. Three different ways (that I know of) to get water in there. Enough for youThanks. I'll see if I can adjust the latches, first. I had thought to do that, earlier, but had forgotten about it, until I read your post. If that doesn"t work, I will resort to the new seals.
The forward cooler drain fitting can also leak.. Mine did, before I sealed around it, a few months back.I hope it works. I'm always finding things on this boat I didn't know were there. Like the drain from the storage area into the changing room. At first it was the anchor drain, then the drain plugs, and now the scupper that drains into the room. Three different ways (that I know of) to get water in there. Enough for you? Certainly for me! After fixing all three I finally have a dry room.
Ha! Good memory. You're right. I forgot that one. I must have put four ounces of silicone in there too. It was seated at about a 20 degree angle. Flush fitting? Not in the factory vocabulary.The forward cooler drain fitting can also leak.. Mine did, before I sealed around it, a few months back.
My new solution for dry storage in the “head” is going to be:
Plastic tote with latching lid on the floor... Closet hanger rod across the top of the compartment with velcro loops to hang life vests and wet suits from.
I had considered that when I saw his post. But since taking care of those four issues I've had a dry room. I was impressed by the work though. Keeping my fingers crossed water doesn't find a new way in I don't know about. Since I don't really go out in the rain, I think I'll be okay... For now‘Out on the Reef’ has a great solution to add a teak platform to the floor, as well:
