- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
While building the new RV barn, and previous with the boat, or on household projects, I used a small, low cart, similar to a wheel barrow but lower. We used this cart as a dock cart too. But I had always hated that it wasn't at countertop height. So I built one!
I thought some of you might want to build your own. I used a Kreg Jig to drill pocket holes to assemble all the pieces. That is the perfect too to attach a piece of lumber to another tight and strong.
The cart tables are 23"w X 30" long, with a handle arm that projects the top two side rails 36". I topped both tables with 1/2" plywood secured with 1 1/4" deck screws. The handle I attached and made from 5/16" all thread rod, inside of 1/2" pic, wrapped with 1/2" pipe insulation. I made three bushings out of some 1/2" tubing, with a 1/4 of it sliced lengthways out of each piece, to allows tight wrap around the all thread and to fit snug inside the pvc. I am going to make a removable table rim and pad the surfaces with tool box liner. I used 4" castors, the front swivel and lock, the rear are non articulating. The cart should hold 300-400 pounds easily.
This cart cost me about $45, as all I had to buy was the castors, all the other material I had on hand, leftover from previous projects.
