- Royal, AR
- SX
Got it... that will help me set up my rule... Thank you for all you guys do!
Ok, got that @Bruce. Guess it was fixed after the last help test was done. Thanks.
I'm in the same boat.Well... @MOA_Chaser 's last @ help request did generate an alert for me on the site, but it did not generate a "tagged" alert, which I assume would have generated an email. Only after I replied to the thread did it start generating emails... just trying to figure out what I m doing wrong.
I thought the same thing but my email has an audible alert on my cell phone so it would get my attention much sooner than my checking the forum.I'd sign up for the e-mail alerts but I check in HERE more often than I check my e-mail...
@john94s1. A belated welcome to the forum. The "at help" feature is used by members if they are on the water and have a problem with their boat that may affect its operation or safety. It is NOT used if peoples lives or safety are at risk. For that you want to go through normal emergency channels in your area.I joined. How does it work? I will be living on a chain of lakes as of next month and would be happy to help anyone in need on my chain if i am home.
Sounds like the 20 amp fuse on the wall next to the battery has blown. Checkout this thread, https://jetboaters.net/threads/no-electric-to-accessories.6928Here's one. Just lost all power to lights radio and cigarette lighter. Clearly a fuse. Anybidea where it is and is it a "circuit. Breaker" type I can just flick/reset or do I need a fuse? 2oo8 sx230 thanks!
Thank you Andy. I will check in a few days before I go out again. Is this one of those standard "glass fuses" I can pick up at an auto parts store? If so I will make sure I pick up an extra. I think my tube pump blew it but the odd thing is, all those fuse "buttons" under the particular switches on the dash would not "reset." Would this fuse you speak of blow the power to all my accesories? Thanks.Sounds like the 20 amp fuse on the wall next to the battery has blown. Checkout this thread, https://jetboaters.net/threads/no-electric-to-accessories.6928
As @Murf'n'surf said it is a standard 20 amp blade fuse. And yes that fuse being blown will kill all the helm accessories.Thank you Andy. I will check in a few days before I go out again. Is this one of those standard "glass fuses" I can pick up at an auto parts store? If so I will make sure I pick up an extra. I think my tube pump blew it but the odd thing is, all those fuse "buttons" under the particular switches on the dash would not "reset." Would this fuse you speak of blow the power to all my accesories? Thanks.
