captainhook
- Southern Maryland
- Limited
I have an opportunity to purchase a Float-On aluminum trailer for $850. However, it is much larger and heavier duty than my current galvanized EZ Loader for my 2008 232 Limited. It is about 7’ longer, larger wheels, and has 6000lb torsion axles. This is not the typical aluminum trailer I’ve seen and it alone weighs 1000lbs according to the build plate and can support 10,000lbs. It previously was used for a 25ish’ fishing boat that sank in a storm.
In my estimation, this trailer is worth at least $2500 and my current trailer is in need of work (brakes, fenders, lights, and probably an axle or two soon). However, I’m not sure my boat will reasonably fit on it. The rear cross member is not angled like my current trailer, it only has two bunks, and the bow roller support is not adjustable for a shorter boat.
I’m thinking of adding two more bunks to support the bow, raising the rear bunks to decrease possibility of hitting the trailer with the keel, and moving the boat forward on the trailer. My concerns are that there will be too much tongue weight and it will be hard to launch/recover in the shallow ramps I use. Aside from cost and frustration.
Has anyone done this sort of thing? Does it make sense or am I just better off buying a new trailer? The other issue is this doesn’t have a swing away tongue so will take up a lot more room in the driveway. Buying it to sell to fund a new trailer is not an option due to a family friend type deal.
